2000 Dodge Caravan idle
2000 DODGE CARAVAN
141,000 MILES • 4 CYL • FWD • AUTOMATIC
CRTRMRCS
knock sensor, throttle position sensor, mass air flow sensor, idle control sensor. Timing belt, vaule job. All have been done, but no luck. Motor runs fine at driving speed, but will not idle right. (lopes) Fuel pressure o.k. Don't know what it could be. HELP.
Dec 13, 2008 at 7:58 PM
ZACKMAN
  • 4,202 POSTS
You have a vacuum leak. Find this leak. Check your vacuum hoses, make sure they are all good, not frayed, disconnected or broken. Also check your EGR valve. Sometimes, plugged up EGR will give the same symptom, and may leak through the gasket.
Dec 14, 2008 at 2:44 PM
