2000 Dodge Caravan Code 23!!
2000 DODGE CARAVAN
14,600 MILES • 6 CYL • 2WD • AUTOMATIC
NALLEN524
What would be code 23 for a 2000 dodge caravan?
I know for a 1995 dodge caravan code 23 is the Throttle Position Sensor, would it be the same for mine?
Whatever it is its making my transmission in Limp Mode.
I did the code check on my digital dash and it said 23 the 55(end of message).
Everyone I talked to said that after 1996 the only way to get the codes are through the scan tool and are like p0951 or something.
So im lost can someone help me please?
Jun 29, 2009 at 1:02 PM
BLUELIGHTNIN6
  • 16,542 POSTS
You will need to have the codes retrieved with an OBD-II scanner. If you don't have a diagnostic scanner, most auto part stores will run the scan to retrieve the codes for you, free of charge. Let me know what code(s) you retrieve.
Jun 29, 2009 at 1:10 PM
