WHEN BREAKING I FEEL VIBRATION FROM LEFT REAR WHEEL, BUT IT DOESN'T FEEL IN THE BRAKE . CAN THIS BE A WHEEL BEARING OR SHRUT PROBLEM
May 31, 2009 at 10:22 AM
JALOPYPAPA
MEMBER
You usuallly hear a bad front wheel bearing before you feel it, a low hum when driving on a curvy road about 40-50 mph and steering the direction opposite that wheel. Possibilities for vibration are a bad tire or a worn axle, tie rod end or ball joint. But the fact that it occurs when you're braking suggests that it is in fact brake-related, most likely a warped rotor.
