1999 Dodge Caravan Blower motor
1999 DODGE CARAVAN
80,000 MILES • 6 CYL • FWD • AUTOMATIC
DARIN113
I still have power running to the blower motor after the ignition is turned off. All fan speeds work with the key removed from the ignition. I swapped the relay and this did not fix the problem. Nothing else is being powered when the key is off. Removing the relay cuts the power to the blower motor.
Mar 18, 2009 at 7:51 AM
JAMES W.
  • 2,394 POSTS
The signal to close the blower comes from your heat/ ac selector switch. If the blower "on" contacts are bad in switch, the relay won't open. Hope this helps.
Mar 18, 2009 at 11:15 PM
DARIN113
If the ignition switch in the on position supplies the power to the circuits, how can the circuit be powered with the switch in the off position. The van does not have a heat/ac switch it has temperature controls, and a switch to direct air flow, push button to turn on air conditioner which operates fine in turning the air on or off and the fan motor speed which also operates fine at all speeds
Mar 19, 2009 at 7:46 AM
JAMES W.
  • 2,394 POSTS
Do you have auto temp control where you push buttons to raise/lower the temp?
Mar 19, 2009 at 2:13 PM
DARIN113
There are slider controls for the temperature, drivers side and passenger. The problem of the blower motor being powered when ignition is off went away, and now the high beams are on all the time instead, swapped the relay for them and this did not fix. Somthing strange going on in that car. No fuses are being blown, just seems random circuits being powered when they shouldnt be??
Mar 21, 2009 at 7:57 AM
JAMES W.
  • 2,394 POSTS
Are the high beams on even when the HL switch is off? OR, when the HL switch is "on", you just can't dim the lights?
Does your van have "daytime running lights" DRL?
Mar 21, 2009 at 8:15 AM
