alarm system
1999 DODGE CARAVAN
WRECKED77
  • 4 POSTS
hi after about a year of my moms van sitting in her garage..she decided to sell her van....so obviously the battery was dead. i replace it with a brand new battery.. now when i open the door, the dash lights, and parking lights start flashing like the factory alarm is going off..
so i start the car, drive around the block and still the alarm keeps going off... what would cause this....do i have to "reset" something because i put a new battery in?
thanks for any help!
chris
Mar 9, 2010 at 3:10 PM
CARADIODOC
  • 34,306 POSTS
Unlock one of the front doors with the key.
caradiodoc
Mar 10, 2010 at 10:59 AM
WRECKED77
  • 4 POSTS
i tried that.. i know the keypad has a dead battery...im gonna try and get a new battery for that and lock and unlock the doors with that and see if that works..
thanks for the reply
chris
Mar 10, 2010 at 11:11 AM
CARADIODOC
  • 34,306 POSTS
The remote should work too. If it does, and the doors don't, look for broken wires between the door hinges, or the switches are broken or disconnected.
caradiodoc
Mar 10, 2010 at 11:51 AM
WRECKED77
  • 4 POSTS
ok i tried everytihng i could think of.. still the alarm keeps goin off while i drive the van? any ideas?
thanks
chris
Apr 1, 2010 at 12:04 PM
CARADIODOC
  • 34,306 POSTS
Actually, if you're driving the van, it isn't in theft mode. The only thing the dash lights and running lights have in common is the Body Computer. That computer adds a lot of complexity and unreliiability to otherwise simple circuits. Unfortunately there is no easy way to test it other than to replace it. It sits up high against the firewall, inside the passenger compartment, ahead of the brake pedal. It unplugs when you pull it down, that's why troubleshooting is next to impossible.
caradiodoc
Apr 1, 2010 at 1:07 PM
WRECKED77
  • 4 POSTS
Idk if this helps but when I turn the headlights on the lights stop flashin. Thanks
Apr 1, 2010 at 1:18 PM
CARADIODOC
  • 34,306 POSTS
The dealership mechanics, and some independent shops with hand-held computers that can access the Body Computer can use it to activate various functions and to read the state of the sensors and switches feeding the computer That will give some clues as to whether the computer is acting up or if it is responding to something.
caradiodoc
Apr 1, 2010 at 1:27 PM
BERIGUY
How can I disconnect the anti-theft device on my car?It has failed somehow and won't let me start the engine. thank you.
Dec 8, 2018 at 1:50 PM (Merged)
BMRFIXIT
  • 19,053 POSTS
You cannot bypass the alarm on this car. Let try to reset the system by following this guide.
https://www.2carpros.com/articles/how-to-reset-a-security-system
Please run down this guide and report back
BERIGUY
Thanks for the guide followed the hard reboot instruction and bam! all fixed thanks:)
BMRFIXIT
  • 19,053 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
DIANNE TEXEIRA
Electrical problem
1996 Dodge Caravan 6 cyl Two Wheel Drive Automatic
My factory alarm went off when I went to open door and wouldn`t shut off,after I was able to get it to shut off it wont turn over,all the lights work,the radio works,but thats all I get.what can be the problem?
BMRFIXIT
  • 19,053 POSTS
Disconnect the BCM
wait a few and then reconnect BCM and try
check battery if low and check fuses 1st
WALTERC
Electrical problem
1998 Dodge Caravan V6 Front Wheel Drive Automatic 150000 miles
I have a 1998 dodge grand caravan and the battery ran down and when I attempted to jump start it the intrusion alarm went off and the car would not start . I put another battery i that was already charged and when I connected the new battery the alarm went off and the car would not start.
EDI3000
  • 34 POSTS
Alarm and no start. Try unlocking the tailgate with the key, if that doesn't work, try same with passengers door.
DAVE1955
my factory alarm system keeps shutting down and takes along time to reset not letting my van to start
I hate to say it, but a dealer is the only place that will have the proper test equipment to check it.
CYNLOY
I just need to know how to disengage the alarm on my 1998 Dodge Caravan??
If it is a factory alarm, you need to have a dealer do the work.
BEARMAN76
I have a 1998 Dodge Caravan. Recently bought it off a guy who cut the factory alarm to shut it off. Now, the van back hazard lights always blink unless the headlights are on. And, after about 2-3 miles the van completely shuts down and has to be jump started. Help!
CARADIODOC
  • 34,306 POSTS
You can't "cut" the factory anti-theft system. When it is activated, the engine will run for only two seconds, then stall. It sounds like you have a charging system problem. Jump-starting is the clue. That won't overcome any anti-theft system. If you charge the battery at a slow rate for over an hour, you'll find the van runs a lot longer.
Start by using an inexpensive digital voltmeter to measure the battery voltage while the engine is running. It must be between 13.75 and 14.75 volts. If it is low, measure the two voltages on the two small nuts or the two small wires plugged into the back of the alternator. Those must be measured with the engine running. Holler back with those numbers.
JROCKIN103
  • 5 POSTS
Can i have my key pad re programmed at a car alarm shop or the dealer or jusf get another key pad alarm?
Dec 8, 2018 at 1:51 PM (Merged)
HMAC300
  • 48,601 POSTS
dealer for re programming but if you normally buy anew one there they reprogramm all of them at asame time
