1998 Dodge Caravan runs hot when a/c is on?
1998 DODGE CARAVAN
13,000 MILES • 6 CYL • 2WD • AUTOMATIC
SPEEDY2RUN
O.K, my question is we have replaced the fan relay twice, and the ecu, the thermostat and the radiator and hose. The car is still running hot. We had it a diagnostic test ran on it and they said repalce the ECU, so we did. It was o.k. for 2 days and then did the same thing. The fan relay blew again! We wired the fans directly ans they are good. So where do we look next, besides a cliff to push it off of!! Any help would be appreciated. Your site is wonderful!! Thank you.
Sep 11, 2010 at 1:50 PM
Hi speedy2run, Welcome to 2carpros and TY for the donation
You probably have a short between the relay and the computer or the wiring from the relay to the fan motor
Did you bleed the cooling system after you replaced the Stat and the Rad?? If not try bleeding it out-don't work get it block and pressure tested to confirm its not the headgasket, cracked head or block and ab intake leak
Sep 11, 2010 at 9:19 PM
SPEEDY2RUN
Thank you for your response. We are on our way to get it checked out again. Hopefully right this time. Appreciate your time.
Sep 13, 2010 at 2:48 PM
