I've had problems where the headlights and interior dash lights would flash on and off both with the engine running and when it is shut off. Also the wipers would stop working in the intermittent setting and would run on at times after they were shut off. Now I can't start the vehicle, and when I try, the relay in the PDC clicks repeatedly until you disconnect the battery. My mechanic says it's the bcm, and that chrysler has to code it before it can be installed. Seeing as money is tight, I'd like to do this as cheaply as possible. Could it be a bad ground? And if not, is the bcm something I can pick up at a junk yard and put in without coding. Or could I get one from the junk yard and have it recoded?
Sep 20, 2008 at 8:21 PM
