1998 Dodge Caravan Parking/ turn signal lights flashing
1998 DODGE CARAVAN
109,000 MILES • 4 CYL • 2WD • AUTOMATIC
TOMWEEDON
The parking lamps/ turn signal lamps flash on an off when vehicle is turned off, headlamp switch is off and door is shut. When any door is open, the "headlamp on" chime sounds. When driving the vehicle there is a slight smell of electrical burning. Headlamp switch gets hot, even though it is turned off. I replaced the headlamp switch with a new one. Problem still exists.
Jun 19, 2008 at 9:58 AM
Inspect and test the park lamp relay in the power distribution center for a start before we go into other components involving the the park/turn lights.
https://www.2carpros.com/forum/automotive_pictures/12900_park_lioghts_1.jpg
Jun 19, 2008 at 6:46 PM
TOMWEEDON
I tried your suggestion and replaced the parking lamp relay. The problem still exists.
So far I replaced the head lamp switch and the parking lamp relay. Any other suggestions?
Jun 20, 2008 at 10:13 AM
Check the BCM ( body control module ) and the combination flasher/DRL module.
https://www.2carpros.com/forum/automotive_pictures/12900_bcm_1.jpg
Jun 20, 2008 at 2:05 PM
