1998 Dodge Caravan oops
1998 DODGE CARAVAN
RICBEC
Brakes problem
1998 Dodge Caravan Two Wheel Drive
cuisin tried do do rear brakes and went wrong way on adjuster trying to take off drum now all is frozen solid tryed everything even drilled a hole to push clicker out.. can we cut pins from backing plate or what? dont know
Dec 28, 2009 at 6:10 PM
CARADIODOC
  • 34,306 POSTS
Yes, you can cut the pins or grind the heads off. You can buy new ones from the dealer or they are also included in the hardware kit available from the auto parts stores.
caradiodoc
Dec 28, 2009 at 9:15 PM
