1998 Dodge Caravan I can't get three monitors to set
1998 DODGE CARAVAN
12,000 MILES • 6 CYL • FWD • AUTOMATIC
TIMOT4576
  • 4 POSTS
They changed this motor from a 3.3 to a 3.8 I bought this van. It sat for a year or so they put this 3.8 motor in it ran good for a while then threw a trans code. I had to put a trans in since all this and I can't get three monitors to set One monitor cat,egr, oxy sensore I changed the egr system and front upstream oxy sensor. When cold I idle car three minutes with everything on. I drive the car 50 mile per hour three minutes then slow to 20 mile per hour then 50 again for 5 minutes then slow to 20 mile per hour still the momitors don't set any idea what I should do? I have no codes set. Thanks if anyone can help
Oct 21, 2010 at 7:39 PM
What computer are you using, one for the 3.3 or 3.8? Also, is the converter good? Have you checked the O2 sensors to make sure they are switching between a rich / lean mixture? (.08 volts rich - .03 volts lean)? Is the EGR plugged?
Oct 29, 2010 at 11:30 AM
