1998 Dodge Caravan help
1998 DODGE CARAVAN
POTOWNSHERYL
Noises problem
1998 Dodge Caravan 6 cyl Front Wheel Drive Automatic
My 98 Caravan, 131,000 miles has slight vibration in tires, began making intermittant metal noises in front end and this morning there was a rubbing sound like the tires were against something. Even though the tire pressure read correct poundage, it seems like my tires are low. Sometimes it sounds like the noise is in the rear.
Aug 27, 2009 at 8:40 AM
CH112063
  • 1,320 POSTS
Have the tires inspected, the belts my have shifted inside the tires. Also tell your mechanic about the vibration and metal sound. It may be a balance problem but the tires are a critical safety item. Please have this done as soon as possible. Be safe, good luck.
Aug 27, 2009 at 7:28 PM
