1998 Dodge Caravan Dodge Grand Caravan 3.8L low oil pressur
1998 DODGE CARAVAN
12,000 MILES • 6 CYL • FWD • AUTOMATIC
DAVES694
Oil pressure warning light comes on at idle in Drive when engine fully hot. Idling at 700-800 RPM. Light goes off when RPMs increased. Oil level full & have done regular oil & filter changes every 3500-4500 miles.
Nov 24, 2008 at 2:24 PM
Check the oil pressure with a mechanical gauge-if normal -replace the oil pressure switch -if it continures to go low-could be the oil pump/engine bearings etc.
Nov 24, 2008 at 2:28 PM
DAVES694
[quote:5385e37555="rasmataz"]Check the oil pressure with a mechanical gauge-if normal -replace the oil pressure switch -if it continures to go low-could be the oil pump/engine bearings etc.[/quote:5385e37555]
That's what I thought....thanks.
Nov 24, 2008 at 4:09 PM
