1998 Dodge Caravan Dash board
1998 DODGE CARAVAN
15,000 MILES • 6 CYL • AWD • AUTOMATIC
CFD110
How do I remove the instrument cluster
Oct 10, 2009 at 8:23 AM
BMRFIXIT
  • 19,053 POSTS
INSTRUMENT CLUSTER BEZEL
Removal & Installation
Remove steering column cover and instrument panel left-side end cover.
Remove screw at left end of cluster bezel and headlight switch. Remove cluster bezel-to-instrument panel screws from each side of steering column.
Disengage clip holding cluster bezel to instrument panel above right vent louver.
Carefully separate cluster bezel from instrument panel. Unplug wire connectors from back of bezel.
INSTRUMENT CLUSTER WITH ELECTRONIC TRANSMISSION RANGE INDICATOR
Remove instrument cluster bezel.
Remove instrument cluster-to-instrument panel screws.
Rotate top of cluster outward and remove.
Unplug wire connectors from cluster. Remove instrument cluster.
To install, reverse removal procedure.
INSTRUMENT CLUSTER WITH MECHANICAL TRANSMISSION RANGE INDICATOR
Remove lower steering column cover and metal knee-blocker panel. Disconnect transmission range indicator cable from shift lever and steering column. Remove instrument cluster bezel.
Unplug wire connectors from back of cluster.
Remove instrument cluster while guiding range indicator and guide tube through opening.
Oct 10, 2009 at 1:40 PM
