Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Dodge
Caravan
Exterior Light
Brake Light
Fuse
1998 Dodge Caravan brake lights
1998 DODGE CARAVAN
133,000 MILES • 4 CYL • FWD • AUTOMATIC
POOHPOOH2468
MEMBER
1 POST
FOLLOW
when I press the brakes the brake lights don't come on. Is it a fuse, and if so, which one?
Apr 23, 2009 at 8:57 PM
CERTIFIED EXPERT
Disconnect the brake switch jumper the wiring connector if light comes On replace the switch if not check fuse.
Apr 23, 2009 at 9:03 PM
CARADIODOC
CERTIFIED EXPERT
Fuses pop for a reason. Do you have a trailer connector? It's common for the wires to get chewed up and become shorted.
Did you check the bulbs? The turn signal bulbs are not the same as the brake lights.
caradiodoc
Apr 27, 2009 at 2:46 AM
