1997 Dodge Grand Caravan Tune-Up
1997 DODGE CARAVAN
CCDOOBER
I will be doing a tune up on a friends 1997 Dodge Grand Caravan with the 3.3L engine. Most likely it will need plugs and wires. Are there any surprises that I will run into when trying to get at the plugs? Is there anything else that I should look at while doing this tune-up?
Thanks!
Aug 17, 2007 at 1:30 AM
[quote:a74bafd90a="ccdoober"]I will be doing a tune up on a friends 1997 Dodge Grand Caravan with the 3.3L engine. Most likely it will need plugs and wires. Are there any surprises that I will run into when trying to get at the plugs? Is there anything else that I should look at while doing this tune-up?
Thanks![/quote:a74bafd90a]
If you don't intend to check engine compressions, the tune-up is useless. There's a lot more involved in todays tune-up then just plugs and wires.
Aug 17, 2007 at 1:45 AM
SERVICE WRITER
  • 9,123 POSTS
https://www.2carpros.com/forum/automotive_pictures/30961_note_34.jpg
The back 3 plugs are a bit of a challenge, but take your time. I would also replace the fuel filter. There is a fuel filter that fits the long wheel base and a different one for the short wheel base. So you need to find that out. The air filter is a small project and that should definitly be looked at/changed. The air filters on these are often neglected. May want to consider the pcv valve. Another part of any tune up I do is a carbon removal procedure. Follow the direction on the can:
https://www.2carpros.com/forum/automotive_pictures/30961_seafoam_2.jpg
http://www.seafoamsales.com/motorTuneUpTechGas.htm and clean the throttle plates, Use a plitic britle brush for this...a bottle washing brush works well. https://www.2carpros.com/how_to/how_to_tune_up.htm
Aug 19, 2007 at 8:40 AM
