Our van won't shift from first gear
1997 DODGE CARAVAN
135,598 MILES • 6 CYL • FWD • AUTOMATIC
JOEHILL
Our van won't shift from first gear. Codes read speed sensors and transmission module. We have replaced, both sensors, module and computer. Nothing has helped also the speedometer is not working,and the PRND3L is always lit up. What else could this be?
Jul 20, 2008 at 9:39 PM
BMRFIXIT
  • 19,053 POSTS
what about the tranny solenoid check TCM power supply
https://www.2carpros.com/forum/automotive_pictures/99387_caravan_tranny_10.jpg
Aug 15, 2020 at 12:19 PM
RACHAELH
curious if the silenoid helped? I am currently having the same exact problem as you explained. replaced same things as you and no difference. curious if you were able to get it figured out need help myself.
Thanks
