1997 Dodge Caravan light off
1997 DODGE CARAVAN
145,000 MILES • 6 CYL • AWD • AUTOMATIC
PRINCE13
first, excuse my english, is not very good. but this is my trouble: the turn lights, engine service, emergency lights ahd all this lights of signing inside, do not work, but the lights ouside works correctly when activate every light. and the 12 volts connectors have not voltaje.
Feb 22, 2008 at 5:28 PM
MASTERTECHTIM
  • 4,750 POSTS
have you checked the fuses. thats where i would start. does the speedometer work?
Feb 22, 2008 at 5:33 PM
PRINCE13
yes, i have checked all fuses inside the van, and the speedometer is working ok, all the others systems works properly, except this line of element, oh, and the horn not works when i press to horn, but when the panic button on the keys is presses, it horns ok.
Feb 22, 2008 at 6:02 PM
MASTERTECHTIM
  • 4,750 POSTS
this is quite i tricky one. it sounds like there a couple problems, possible bad dash cluster and horn wiring or horn pad. unfortunately here is about as far as we can go without doing extensive diagnostics
Feb 23, 2008 at 7:24 AM
