1997 Dodge Caravan Drivers side axle replacement
1997 DODGE CARAVAN
98,000 MILES • 6 CYL • FWD • AUTOMATIC
MIKEWALLOCH
I need advise on how to replace the drivers side axle shaft. (Bad CV joint) I have done Hondas but want whatever advise I can get. i,e. remove tire, remove caliper, remove hub etc. and any pitfalls to avoid. Thanks. Mike Walloch
P.S. I already have the NEW complete axle shaft in hand from the dealer. Thanks.
Jun 4, 2009 at 11:15 AM
DOCFIXIT
  • 18,828 POSTS
Hi
You can do Honda this will be childs play. Like you said caliper. ABS sensor if have. Tie rod end& lower ball joint. Turn wheel out as far as possible the remove cotter and nut then strike the boss area on spindle to release ball joint. Pull out on spindel /strut and push stub axle through hub. Then pry between inner CV and trans then remove axle.
Hope this helps
Thanks for donate
Jun 4, 2009 at 3:07 PM
