1997 Dodge Caravan change headlight switch
1997 DODGE CARAVAN
STEPHANS
Electrical problem
1997 Dodge Caravan Front Wheel Drive Automatic
how do i change the head light switch?
Apr 26, 2010 at 9:04 PM
TOOOMANYTOYS
  • 513 POSTS
Remove instrument cluster bezel.
Remove screws holding the headlamp switch bezel to cluster bezel.
Disconnect the wire connectors from the headlamp switch and wire connector from the power mirror switch.
Remove headlamp switch bezel from cluster bezel.
INSTALLATION
Install headlamp switch bezel from cluster bezel.
Connect the wire connectors from the headlamp switch and wire connector from the power mirror switch.
Install screws holding the headlamp switch bezel to cluster bezel.
Install instrument cluster bezel.
Apr 26, 2010 at 9:19 PM
