Right turn signal does function. I have replaced the switch and the front and rear bulbs. Can't seem to figure this one out. Because the problem is intermitent. Sometimes it works some it does. Most of the time it does work. I thought about replacing the turn signal relay, but when I call the dealer for the part they said it could be the BCM (Body control module). The BCM is way more expensive then the relay. Am I on the right track? Should I just keep replacing parts until I get the right one? Help!
Apr 7, 2009 at 12:54 PM
