1996 Dodge Caravan Turn signals
1996 DODGE CARAVAN
SWTFRE
1996 Dodge Caravan
I have a 1996 dodge caravan and I cant figure out why the turn signals wont work(left or right), I have checked all the fuses and they are ok.. The hazards (four way lights) are fine, head lights work, high beams work, brake lights work, but not turn signals. I was told that the it could be the relay, but since the hazards work that was ruled out.. Someone Help...
Mar 25, 2010 at 7:15 AM
I need you to check something. In the front fender well there is a round plastic screw out plug (about 6 inches dia). Remove it to access the wiring to the signal bulb. Check both plugs where the power supply and the bulb wiring come together. When you unsnap it, check for broken pins and corrosion problems. Make sure to check both sides.
Let me know what you find.
Mar 26, 2010 at 1:04 PM
