1996 Dodge Caravan ignition issues
1996 DODGE CARAVAN
185,000 MILES • 6 CYL • FWD • AUTOMATIC
SBURROWS63
  • 4 POSTS
I have a 96 Grand Caravan. Over the last couple of weeks, when turning the key, it would click in the power distribution center but the starter would not kick in. Turning the key a time or two then it would start. Now the problem is to the point it will rarely kick the starter. I have replaced the 40 amp fuse and the starter relay to no avail. The starter was replaced about a year and a half ago. Could this problem still be due to a faulty ignition switch even though you can hear the current hit the relay. The key cylinder turns normally and does not stick.
Jan 12, 2010 at 8:47 PM
BMRFIXIT
  • 19,053 POSTS
I would suspect and check starter 1st
Jan 12, 2010 at 9:03 PM
SBURROWS63
  • 4 POSTS
[quote:65c23a6267="BMRFIXIT"]I would suspect and check starter 1st[/quote:65c23a6267]
Thanks for the very quick response. I was really hoping to avoid pulling the starter as it was loads of fun the last time.
Jan 12, 2010 at 9:51 PM
