I think code 23: Is Incoming air temperature sensor may be bad.
code 42 : Automatic shutdown relay circuit open or shorted.
Jun 9, 2007 at 3:44 AM
GLENFRANC
MEMBER
what is code 55 ?
Jun 26, 2007 at 2:13 PM
ROGERDOGER
MEMBER
There are relays under the hood. Look at the diagram on the relay cover. Try changing some of them around to see if a relay or two is bad.
Aug 16, 2007 at 11:38 PM
L_BOURGON
MEMBER
32 EGR gases not working
42 Automatic shutdown relay circuit open or shorted
42 Fuel pump relay control circuit
42 Fuel level unit - no change over miles
OR
42 Z1 voltage missing when autoshutdown circuit energized
55 End of codes
