1995 Dodge Caravan Front Window Wiper Motor
1995 DODGE CARAVAN
ABBYGIRL
Electrical problem
1995 Dodge Caravan 6 cyl
While driving, wipers stop working. Even tried to make them work with by using the washer fluid which makes them come on automatically. There was no noise, nothing.
Is this a fuse blown or wiper motor(front).
If motor, how much would a motor run for this type of vehicle?
Sep 3, 2009 at 6:12 PM
BLUELIGHTNIN6
  • 16,542 POSTS
First check fuse # 5 (20-amp / yellow ) . If fuse is OK, check voltage at the wiper motor. If voltage is present, replace the motor. If voltage is not present, check the wiper switch, ground circuit and wiring.
Sep 3, 2009 at 8:10 PM
