1995 Dodge Caravan abs
1995 DODGE CARAVAN
LILIANNEVOUT
Brakes problem
1995 Dodge Caravan Engine Size unknown Front Wheel Drive Automatic 222225 miles
I recently changed my brakes after taking air out of the lines ther eis one problem all the brakes work except the front driver side brakes. Can anyone tell me why this might be
Feb 3, 2008 at 11:05 AM
BMRFIXIT
  • 19,053 POSTS
[quote:e0931009be="liliannevout"]Brakes problem
I recently changed my brakes after taking air out of the lines ther eis one problem all the brakes work except the front driver side brakes. Can anyone tell me why this might be[/quote:e0931009be]
did you bleed air out
do you have fluid and pressure on that side ?/???
check hose and caliper
+++what kind of brake job did you do ?
(lines------- calipers) ?????
Feb 3, 2008 at 7:10 PM
LILIANNEVOUT
we tried to get the air out of lines for approximately thirty minutes no fluid came out
Feb 3, 2008 at 7:45 PM
BMRFIXIT
  • 19,053 POSTS
[quote:85b2c49e4a="liliannevout"]we tried to get the air out of lines for approximately thirty minutes no fluid came out[/quote:85b2c49e4a]
did you check if you have fluid in the line
check that
if so check the bleeder
Feb 3, 2008 at 7:52 PM
LILIANNEVOUT
The fluid is full the bleeder screw seem fine my worryy is that when i depress the brakes they go to the floor. the front drivers side breaking does not work. The two lines after the junction box the shoes calipers and routers on the passenger side was replaced but yet the drivers side brakes are malfunctioning. I have checked all the above components on the driver side all are fine. I have been told it could be the control unit or the master cylinder how can i test these, if these items were gone would it not affect both front or both back brakes as abs are in two components.
Feb 3, 2008 at 8:26 PM
BMRFIXIT
  • 19,053 POSTS
[quote:448006d679="liliannevout"]The fluid is full the bleeder screw seem fine my worryy is that when i depress the brakes they go to the floor. the front drivers side breaking does not work. The two lines after the junction box the shoes calipers and routers on the passenger side was replaced but yet the drivers side brakes are malfunctioning. I have checked all the above components on the driver side all are fine. I have been told it could be the control unit or the master cylinder how can i test these, if these items were gone would it not affect both front or both back brakes as abs are in two components.[/quote:448006d679]
Ask a helper with good and strong legs to sit in the van and pump it for you 5 to 8 times hold it down
you start at the master cylinder lines
open lines one at a time open one ask the helper to pump and hold then open and close the line
do that until making sure no more air in system
work your way down (keep eye on fluid in the master cylinder dont let it run low )
do it rear right front left rear left front right rear
if no fluid out the master cylinder master may be defected
Feb 4, 2008 at 6:45 PM
