1994 Dodge Caravan Power Windows Not Working
1994 DODGE CARAVAN
MAYLA101
1994 Dodge Caravan
I have a 94 Dodge Grand Caravan and recently the Power Windows stopped working, I've Checked Both window Switches on the driver and passenger side to see if the windows would roll up, I've also bought a Bussmann Circuit Breaker as the people in Oriellys told me i needed, Ive gone into the Dash board under the steering Column to Replace the breaker.. but the one's ive found and put the new breaker in its place didnt work.. please! I need Help! I live in 98 Degree weather where it rains all the time! and my windows are more than half way down.... what should i do? or how can i fix this??
-Laura-
Jun 17, 2010 at 1:18 PM
Are you getting power to the switch?
Jun 18, 2010 at 11:06 PM
HINK424
  • 5 POSTS
I have the same issue with only the driver side window. removed switch on driver side and there is power to the passengerr side but no power to driver side. Does that tell you anything? Thanks
https://www.2carpros.com/forum/automotive_pictures/589849_DSC_0343_3.jpg
Nov 7, 2010 at 10:56 AM
That is odd. The power originates at the driver's door. Have you checked to see if there are any wire breaks between the door and the door frame?
Nov 8, 2010 at 7:28 AM
