1994 Dodge Caravan Does not want to accerlate smoothly.
1994 DODGE CARAVAN
MILLER2771
1994 Dodge Caravan 4 cyl Two Wheel Drive Automatic
When I start to drive it hesitates like it does not want to take off, but it does. While i am acclerating it acts like it is jumpy. It is impossible to drive on the highway because my van does not want to drive over 50mph. I got a tune up but it did not solve the problem I also changed fuel injectors a few months ago, but it still isnt accelerating properly.
Thank you
Mar 1, 2010 at 5:45 PM
Hesitation,chugging,lack of acceleration,bogging etc.
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Mar 1, 2010 at 6:03 PM
