1994 Dodge Caravan cigarette ligter
1994 DODGE CARAVAN
BLACKLIPPS
1994 Dodge Caravan 6 cyl Two Wheel Drive Automatic
can u tell me what # fuse i need for the cigarette lighter. ichecked the fuse,s there all good but some are missing about 4 or 5,i took apart the lighter it's connected with the lines. is ther anything eles there could be wrong with it .the only reason i need it is for my gps charging
Jan 11, 2010 at 1:09 PM
JDL
  • 16,098 POSTS
Welcome to the forum, check fuse 3-- 20amp in instrument panel fuse block, not only check fuse, use a testlite, see if fuse circuit is hot, should be hot all the time.
Also, check fuse 58--40 amp in power distrubution center under the hood. Use testlite on that fuse circuit, hot all the time.
Jan 11, 2010 at 2:59 PM
