1994 Dodge Caravan bad starter?
1994 DODGE CARAVAN
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
SQUICKPEEP
I suspected the starter had been going out for a while. Ex occasionally would remove the keys from the ignition while I was still in gear/moving. In the last couple weeks it has been harder to start, takes several tries. One time a jump got it going. This time, it did not, but I suspect the person didn't have it hooked up right. I was told to "bump" the starter. A friendly stranger supposedly did this, with no change. It seems to be getting juice, as the interior lights and noise work, and the batter is only about a year old. When I try to start, there is no turning over, only a slight ticking or humming noise. The stranger told me it was just the starter, not the solenoid, whatever that means. If this is the case, about how much should I expect to pay for a new starter, and how much should I pay (an acquaintance) to replace it? Wish I could donate at this time. Thank you!
Dec 27, 2009 at 5:05 AM
CARADIODOC
  • 34,306 POSTS
Very common problem with an easy fix. The solenoid is the mechanical part of the starter that engages it with the engine during cranking. You are likely hearing one kind of loud clunk when you turn the ignition switch to "crank". When the starter becomes solidly engaged with the engine, electrical contacts in the solenoid switch on the current to the starter. This is done so the starter motor is not spinning until it is engaged. That prevents grinding the teeth of the gears. Those contacts are worn away. If you keep cycling the ignition switch to the crank position enough times, the engine will eventually start, but it will gradually get worse over the next few weeks or months.
The starter is under the engine, right in the front and is very easy to get to. Replacing it takes about ten minutes and you don't have to jack the vehicle up. The battery must be disconnected for safety. Besides the obvious resetting of the clock and radio presets, memorized "short term fuel trims" and "long term fuel trims" will be lost in the engine computer. Most of this will be relearned as you drive over the next few minutes and days. You might not even notice any change in engine performance as this takes place. What you WILL likely notice is the engine probably will not start or will not stay running unless you hold the gas pedal down just a little. The engine computer will not know when it has to be in control of idle speed until it relearns "minimum throttle". It will do that automatically when specific conditions are met. You can make that happen by driving at highway speed with the engine warmed up, then coasting for at least seven seconds without touching the brake or gas pedals.
The worn contacts can be replaced for 20 bucks, but most people just install a rebuilt starter motor which has the solenoid built in. Cost for a new starter is over $400.00. You normally only get a new one when the vehicle is in warranty. You will get a rebuilt or remanufactured starter for less than half of that. I always replace just the contacts. I never bought a replacement starter so I don't know the cost. Other than those contacts, the rest of the starter motor and gear reduction assembly are extremely reliable.
The observation that it started once with a jump-start is a clue. The slightly higher voltage from the running engine helps force enough current through the worn contacts to get the starter motor to spin. It also would eventually have started even without the jump-start.
All of this story is based on your observation that the interior lights stay nice and bright. A less common problem is battery cables that are corroded inside the insulation where you can't see it but that would cause the lights to go out when you tried to start the engine. Your symptoms are more typical, and the worn contacts are very common.
caradiodoc
Dec 28, 2009 at 11:46 PM
