Bosch
Remove starter. Remove 2 starter solenoid field terminal nuts. Remove 3 solenoid mounting screws and remove solenoid. Remove 2 through bolts securing starter drive end housing to motor housing. Remove rubber seal and pull gear and clutch assembly from drive housing. To install, reverse removal procedure.
Nippondenso
Remove starter. Remove 2 gear housing attaching screws and separate gear housing from solenoid housing. Remove pinion gear, pinion gear bearing, and drive gear from gear housing. Remove starter gear and clutch assembly from solenoid housing. Clean and lubricate pinion gear, bearing and drive gear and reinstall in gear housing. Install starter gear and clutch assembly in solenoid. To install starter, reverse removal procedure.
Apr 7, 2009 at 8:21 PM
