1993 Dodge Caravan Front wheels are at an angle
1993 DODGE CARAVAN
WEBSPINNER
Tires and Wheels problem
1993 Dodge Caravan 6 cyl Two Wheel Drive Automatic
The driver's side front wheel bearing/hub assmby had to be replaced, so a friend removed the old one that appeared to be practically shattered and replaced it with the new one. The current tires on the van are 15", so Im not sure if that is the original size or if 14" is. After he got everything put back together, I noticed that the tires (mostly the drivers side tho) were tilted or angled w/the bottom of the tire to the inside and the top of the tire to the outside. My friend removed the tire and retraced his steps to see what may have gone wrong. Now the tires are back on and the passenger side appears fine but the driver's side still looks like its still at an angle. Can you tell me what may have caused this or does it need a re=alignment???
May 2, 2008 at 7:40 AM
It needs re-alignment is sound like excessive toe-
May 2, 2008 at 7:59 AM
