1992 Dodge Caravan misaligned timing marks and cam degreein
1992 DODGE CARAVAN
102,000 MILES • 6 CYL • FWD • AUTOMATIC
NELSEC
I'm changing the head gaskets and in the process of removing the cam and crankshaft sprockets I lost TDC and moved the sprockets. Now I can't get the distributor pointing correctly or the timing marks alligned. They are all off! What should I do?
Nov 13, 2008 at 11:35 PM
Hi:
You will need to remove the timing belt and reset the timing. If you need a guide, go to the "Popular Site Links" on this page. Select "Drive Belt Routing Diagrams." Put in the vehicle information and it will provide a diagram.
I hope this helps.
Nov 15, 2008 at 12:16 AM
