1989 Dodge Caravan Running rich!
1989 DODGE CARAVAN
200,000 MILES • 4 CYL • FWD • AUTOMATIC
XBLADE
I have a 1989 dodge caravan 2.5L with Turbo, And i cant find out what the problem is with it running to rich. Its at a CO rating of 8.76% which is a 6;1 fuel air ratio.
it also Cuts out at around 4 grand (believed because its to much gas getting to engine)
I have replaced O2 sensor fuel pump and filter cleaned Breather and Replaced the ECU,
What else can i do?? Please help.
PS where is coolant sensor located?
May 12, 2008 at 5:10 PM
Possible causes include a bad O2 sensor, excessive fuel pressure (bad fuel pressure regulator or plugged return line), leaky fuel injectors, dirty air filter or restricted air inlet, or a defective coolant sensor that prevents the engine management system from going into closed loop mode. CTS location see below
https://www.2carpros.com/forum/automotive_pictures/12900_cts_10.jpg
May 12, 2008 at 6:20 PM
XBLADE
Thank you for all the help. I have just replaced O2 sensor, doign Fuel regulator today, Has Plenty of air> Cleaned ALL filters on it. If this doesn't fix the problem ill go with Coolant sensor. thank you anymore Suggestions?
May 14, 2008 at 2:32 PM
