Electrical problem
1989 Dodge Caravan 4 cyl Front Wheel Drive Automatic
I can get the vehical to start at times and it will run until i shut it off. At first it would drive and the engine would die and then it would run fine for a while and then not start. I replaced the distributer, coil, cap, rotor and Engine computer. No such luck, i was told it may be the wiring harness has a short, also was told that the oil pressure switch may be bad.
Like I said it gets fuel but no spark....
Dec 21, 2009 at 8:00 PM
