1989 Dodge Caravan
1989 DODGE CARAVAN
MCREPAIRS
  • 6 POSTS
Engine Mechanical problem
1989 Dodge Caravan 6 cyl Two Wheel Drive Automatic 200 00 miles
runs for a little time then just stalls
Nov 16, 2009 at 5:21 PM
CH112063
  • 1,320 POSTS
Did this just start? All of a sudden? How many seconds, and is it always the same amount of time? 2, 3 seconds?
Nov 16, 2009 at 9:35 PM
MCREPAIRS
  • 6 POSTS
it does it anytime sometimes when youare driving at 55
Nov 16, 2009 at 11:05 PM
CH112063
  • 1,320 POSTS
You can check this engine control system with the engine's 'check engine' light on the dash. Key on, off, on, off, on and watch the blinking check engine light. It flashes numbers. Do this key method all within five seconds. Write them down. Let me know. Take your time, you can do it as many times as you need to. It ends with five, five flashes(55). ok Is this a 3.OL or 3.3L? Mileage is unclear.
Nov 17, 2009 at 10:13 PM
MCREPAIRS
  • 6 POSTS
done that said had trouble code 54 problem with distributor synchrnizatio circuit nosync pickup sigmal during operation put a nother one in plus these codes 23 and 12. 23 is intake air temperature sensor high or low voltage. 12battery power to computer disconnected or memory standby by power lost. then got code 37 is part throttle unlock solenoid driver circuit open or shorted automatic tran yes. engine is a 3.0
Nov 18, 2009 at 7:17 PM
CH112063
  • 1,320 POSTS
Thank-you, if you have no lock-up converter(trans) normal(37). The battery has been disconnected in the last few engine starts code 12(you know), and the 54 is for the dist. pick-up plate, its wiring, or the timing belt is not correct(very possible). The code 23 is either intake temp. or at that time it could have meant that it had none. I never saw an intake air temp sensor on a 3.Ol out here. Just 2.2L TBI. The vehicle speed sensor will shut an 89 3.Ol off at high speeds, with no codes. A distributor optical signal input(code 54) will do many shutoffs and hard or no starts. And if its fuel, it is sometimes hard to tell, electrical or fuel. I would see if it has a lock-up converter, if not the code is normal, if you do, unplug it, may go away(stallimg). After that I would have the distributor out, check or replace the pick-up, or rotor(comes loose). I am sure that it is a code 23 you have read, and not 22, or 24 which would wreak havoc with your 3.oL. I hope you do not have any more trouble. And I hope you have understood my response, also. As I just want you to get your van running properly, and online it is not easy. In 89, it was always no code problems. No codes, because of the response speeds in the computers. Now its better. Hope I helped you.
Nov 18, 2009 at 8:56 PM
