Replaced my brake system and most of my front end on a 1988 dodge Caravan SE-V-6. Getting a rumbling shudder (vibration) from the passenger side ( or so it seems)when the brakes are applied. Even replaced the rotor a second time. Replaced the inner and outer tie rod and the sway bar bushings. Driving me nuts! Got a front end alignment a few weeks ago, and I noticed the inner tie-rod boot all twisted up from him adjusting it. I straightened it out, tested to see if the inner tie rod connection was loose (not). Running out of ideas. The only thing I haven't replaced is the control arm bushings and ball-joint, all which I've bought.
Apr 4, 2009 at 9:04 AM
