1998 Dodge Avenger timing belt
1998 DODGE AVENGER
118,000 MILES • 6 CYL • FWD • AUTOMATIC
1998 AVENGER
I have 1998 doge Avenger, I changed the timing belt and the water pump last year.
Now I have an overheating problem, the car start to over heat after 30 minuets of driving.
I just checked my car today and the mechanic told me that the timing is of and you need to adjust it and it will cost $1000. Please I appreciate any advice.
Thank you
Jul 16, 2010 at 6:39 PM
MHPAUTOS
  • 31,937 POSTS
Hi there, See pic for correct timing belt alignment, $1000.00 is way to much to be doing this, anyway i would be thinking a faulty thermostat or radiator cap or blocked radiator as a first option, i would go get a second opinion on this problem.
https://www.2carpros.com/forum/automotive_pictures/61395_Graphic_156.jpg
Jul 16, 2010 at 6:49 PM
1998 AVENGER
Hello
about the thermostat, I just put a new one last week, and I did a complete coolant system flush. back to the timing belt, any idea how much would it be to adjust the timing.
Thank you
Jul 17, 2010 at 9:14 AM
MHPAUTOS
  • 31,937 POSTS
Hi there.
There still will be around 3-5 Hrs to access the timing belt to re adjust if it dose need it, you will have to check local labour rates.
mark (mhpautos)
Jul 17, 2010 at 11:41 AM
