1998 Dodge Avenger timing
1998 DODGE AVENGER
JEP599
Engine Mechanical problem
1998 Dodge Avenger 6 cyl Front Wheel Drive Automatic
I changed the timing belt, the pin in the cam gear sheared off and lost the timing, do you think that I have bent the valves? is this engine a zero clearance engine
Nov 10, 2008 at 7:48 PM
ZACKMAN
  • 4,202 POSTS
The 2.5L is an interference engine. If you lose the timing while driving, chances are that you will have a couple of bent valves.
Nov 12, 2008 at 9:05 PM
