1997 Dodge Avenger how to remove driver door
1997 DODGE AVENGER
300,000 MILES • 6 CYL • FWD • AUTOMATIC
JORGER04
I have a damaged door and I believe it is the hinges but I need to take a look inside to see what needs to be replaced and how I could fix it.
Can anyone give me the exact steps to taking off the door safely? I am having a bit of trouble because I cannot open it up very far at all just a few inches.
Thanks for the help
Aug 17, 2009 at 6:03 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Disconnect the negative battery cable. Open the door, then support it either with the help of an assistant or a padded jack. Detach the electrical connector at the hinge pillar. Remove the spring pin securing the door check strap to the hinge pillar. Remove the door-to-hinge mounting bolts. Carefully remove the door from the vehicle.
https://www.2carpros.com/forum/automotive_pictures/261618_0900c15280089d37_1.jpg
Apply a suitable multi-purpose grease to the door hinges and door strap spring pin. Position the door on the vehicle and install the door-to-hinge mounting bolts. Tighten the door-to-hinge mounting bolts to 16 ft. lbs. (22 Nm). Install the spring pin securing door check strap to the hinge pillar. Attach the electrical connector at the hinge pillar. Connect the negative battery cable. Perform the door adjustment procedure.
Aug 17, 2009 at 11:33 PM
