1995 Dodge Avenger dashboard lights
1995 DODGE AVENGER
STUPIDTATER
Electrical problem
1995 Dodge Avenger 6 cyl Front Wheel Drive Automatic
on the dashboard there is a light next to the door ajar light that turns on when you turn the car to on position but not over. that light flickers while driving it seems like the light goes on when we go over a bump or engine revs up or idles like the engine shaking is causing it to flicker but not stay on. also when we but some gas on the radio gets statickie when you let go of the gas it stops the static. car seems to run fine no other problems are these signs of something is going wrong or anything
Jan 5, 2010 at 4:18 PM
CH112063
  • 1,320 POSTS
It depends on the small icon that is lighting up at times, it may or may not be accurately lighting up, it may be just a loose connection, try to see exactly what this light is showing thru the lens, maybe its an oil can or coolant warning. It could be a battery signal warning. The wiring and circuits involved with the oil pressure switch were a big weak point on almost every Mitsu engine.
Jan 22, 2010 at 3:46 PM
