1989 Dodge Aries high idling and check engine light
1989 DODGE ARIES
150,000 MILES • 4 CYL • FWD • AUTOMATIC
BIGTED33
I have an 89 dodge aries, when i start it it's fine but when it warms up it high idles and the check engine light comes on,and immidiately shuts off.can anyone help.
Apr 22, 2009 at 7:01 PM
CH112063
  • 1,320 POSTS
Hello, in a way the check engine lamp being on is your saving feature. The computer that controls idle speed through sensor inputs has let you know that the malfunction code is stored in the computer and if you read the computers trouble codes, it will give you the correct sensor failure. Throttle position, idle speed motor, coolant and pressure sensors and more could fail and cause this problem. You must scan the engine controller with a scan tool, write down the codes and then you can determine the failure. The best way is to bring it to a shop and tell them the problem, or get a scan tool, scan it yourself then ask again with specific codes about the problem. Your better off towing it to a shop because the scan tool is not cheap. I hope this helps you to go in the right direction. Any other way is a guessing game.
Aug 27, 2009 at 5:29 PM
