I am in the process of changing the oil pan gasket. I removed the oil pan with some difficulty. It apears that the water pump is in the way. Before I remove the water pump, can you tell me if that is what I need to do or not? What else do I need to remove? Do you recommend a one piece gasket?
Aug 18, 2008 at 6:28 AM
