1985 Dodge 600 car missing
1985 DODGE 600
89,900 MILES • 4 CYL • FWD • AUTOMATIC
WHITEPINELANE
just had a tune up new plugs wires and cap car is still missing when driving does not like to always get up and go at stop signs if i give it gas it works it self out but its a daily thing going on 7 months
Jul 29, 2009 at 2:40 PM
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Jul 29, 2009 at 2:42 PM
