This is a 2004 with the 5.3 correct? What is the engine designation on the sticker under the hood? LM4 or LH6 I ask because GM didn't sell AFM on the 5.3 until late 2005.
Do you have the option under the trip meter to monitor the AFM system?
If you look at the cover under the intake manifold, is it smooth or does it have an electrical connector up next to the oil pressure sender and a lot of cast in oil passages?
If it has the connector it would be the first thing I would check for water intrusion. You can also test the system with a scan tool to see if it has been deactivated for another reason as listed below.
- Engine manifold vacuum low
- Brake booster vacuum pressure low
- Accelerator pedal position rate of increase too high, electronic throttle control
- Accelerator pedal position too high, electronic throttle control
- Ignition voltage out of range
- Engine oil pressure out of range
- Engine oil temperature out of range
- Engine RPM out of range
- Transmission gear incorrect
- Transmission range incorrect
- Transmission gear shift in progress
- All cylinders activated via scan tool output control
- Minimum time in V8 mode not met
- Maximum V4 mode time exceeded
- Engine oil aeration present
- Decel fuel cutoff active
- Fuel shut-off timer active
- Minimum heater temp low, HVAC system
- Reduced engine power active, electronic throttle control
- Brake torque management active
- Axle torque limiting active
- Engine metal over temperature protection active
- Catalytic converter over temperature protection active
- Piston protection active, knock detected
- Hot coolant mode active
- Engine over speed protection active
- Fault Active or Fault Pending-DoD is disabled for the following faults:
- Manifold Absolute Pressure Sensor
- Brake Booster Vacuum Sensor
- Engine Oil Pressure Sensor
- Engine Coolant Temperature Sensor
- Vehicle Speed Sensor
- Crankshaft Position Sensor
- Engine Misfire Detected
- Displacement On Demand Solenoid Driver Circuit
Just want to be sure what you have.
Jan 21, 2020 at 12:04 AM
