My car needs additional coats of paint. Do sand or wet sand before each coat?
Jul 4, 2016 at 8:17 PM
HMAC300
CERTIFIED EXPERT
if you wet sand is best then wash off you can use 400 grit then if you are painting with two step you will need a respirator. you may not need to sand to put on clear coat unless you are waiting a couple of days between base and clear coat.
Jul 5, 2016 at 6:04 AM
ROYCAR71
MEMBER
If additional coats are needed, do I continue to go up from 400 grit or use 400 grit everytime?
Jul 5, 2016 at 12:31 PM
CERTIFIED EXPERT
You can use 600 for an even better finish.
Jul 8, 2016 at 6:43 PM
ROYCAR71
MEMBER
I have orange peel in my final coat without clear coat what can I do to get it smooth and glossy? Thanks.
Image (Click to enlarge)
Jul 9, 2016 at 11:00 PM
CERTIFIED EXPERT
Looking good, wait until its completely dry then color sand it with 800 and then shoot the clear coat.
Jul 11, 2016 at 6:52 PM
ROYCAR71
MEMBER
It still has some orange peel and I sanded through some areas of paint. I am going to shoot one more coat of paint than clear coat. My question is will a few coats of clear smooth out orange peel?
Jul 21, 2016 at 11:33 PM
HMAC300
CERTIFIED EXPERT
most body shops don't sand between color and clear they sand after but I fyou must and want the peel out sand it then clear it then sand again. You may be putting the paint on to heavy causing the problem. you should really check with a body shop guy on this. As mechanics we fix cars not getting into much like specialty stuff like body repair. Especially now a days with the types of paint that are on the market
Jul 22, 2016 at 6:42 AM
CERTIFIED EXPERT
The paint could be to dry as well, turn the paint up on the gun or the air down. Please give us a picture when finished. I would like to see it.
Best, Ken
Jul 22, 2016 at 10:48 AM
ROYCAR71
MEMBER
Here is before and after shots. Can I wait about a week or so to clear? This is marine topdide Alkyd paint, or not clear.
Jul 24, 2016 at 1:20 AM
HMAC300
CERTIFIED EXPERT
as long as the paint is dry you can clear it
Jul 24, 2016 at 8:14 AM
CERTIFIED EXPERT
From the pictures the paint is too dry. Adjust the gun to have more paint and turn the air down a little, if the fan is too wide it will cause this too. You want the paint to flow on there, it is an art. But no matter what you can always color sand and buff when done it will look great.
Jul 24, 2016 at 8:39 AM
ROYCAR71
MEMBER
What be recommended sanding grade before polish? Thanks.
Jul 29, 2016 at 2:31 AM
CERTIFIED EXPERT
Yes, 800, sand smooth then buff and wax, please send pictures when done, we would like to see it
Best, Ken
Jul 29, 2016 at 8:31 AM
ROYCAR71
MEMBER
I have 2-3 coats of rustoleum automotive clear coat over paint, isn't 800 to course to burn through my clear to fast, or can I use 1500 to 2000 than Polish ?
Jul 29, 2016 at 12:44 PM
HMAC300
CERTIFIED EXPERT
800 is fine prior to polishing.
Jul 29, 2016 at 3:20 PM
ROYCAR71
MEMBER
Thanks
Jul 29, 2016 at 5:06 PM
RIVERMIKERAT
CERTIFIED EXPERT
Did you get rid of the orange peel problem Roy? From my experience, that could also be an issue with how you prepped the body for paint.
Jul 30, 2016 at 8:57 AM
ROYCAR71
MEMBER
The orange still exist, I waxed and buffed it smooth out orange peel some.
Aug 14, 2016 at 9:48 PM
CERTIFIED EXPERT
The images didn't turn out can you reload them?
Aug 15, 2016 at 11:47 AM
ROYCAR71
MEMBER
Sorry I took long to reply. Had problems uploading. I'm little disappointed because paint looks spray painted. Currently, I am experimenting with car wax to get better gloss. Any ideas will be appreciated thanks.
Aug 20, 2016 at 1:56 AM
CERTIFIED EXPERT
Color sand and buff keep at it and it will look better
