Thanks Ken!
The original transfer case, had an encoder motor on it but I do not have that motor currently as I replaced it with a salvaged model.
As far as issue, I originally swapped out AWD transfer case for 4x4 transfer case leaving the VSS unplugged. As a result, I only had first and second and my transmission is all electronically shifted. Swapped out 4x4 TC with correct AWD TC but had broken VSS on TC so could not plug in. Had first and second again but a little later I had I no gears.
After changing ATF, and filter, I verified I had no gears still. So I unplugged battery for about thirty minutes and back in and I had first for about six feet. Keeping in mind VSS is still unplugged.
I think it is VSS but not sure. Anyways, I do not have encoder motor physically with me but I did not see why I would need it anyways.
Sep 5, 2017 at 12:48 PM
