Yes absolutely you have to bleed them when you install a new master cylinder to remove any air water dirt and old fluid that might be trapped in the lines or you won't get enough system pressure for the brakes to operate properly and as you bleed them you should get your pressure back and your brakes working good again ..good luck hope this helps.. .
Jul 12, 2025 at 9:51 PM
