Hello, I have found out that my vehicle listed above (Outback model DOHC engine) is leaking oil through the valve cover cover gasket. I went out and bought the valve cover gasket from Napa. I got home and I took out the windshield washer reservoir and disconnected the battery. Then unplugged the wire from one spark plug and unscrewed it as well. Now since i do not know if I could/should put the new spark plug back in where I took out the old one before or after I replace the valve cover gasket? And if it is after then how do I replace it?
Dec 8, 2017 at 12:21 PM
