Distributor Mount
1997 HONDA CIVIC
113,000 MILES
DEESCHMEE
The bracket that thr distributor bolts onto at the cam-end of the valve cover has snapped off pulling the didtributor away from the cam and leaked all my oil out. What is this bracket called?
Apr 28, 2013 at 4:48 PM
FREEMBA
  • 1,152 POSTS
On that Honda, that bracket is a part of the (rear)Camshaft bearing cap. You'll need to get a new bearing cap in order to fix this problem. Good thing is, they are easy to find in local salvage yards. You'll have to remove the valve cover to access it and be sure to replace the distributor O-ring seal.
Apr 28, 2013 at 5:24 PM
DEESCHMEE
Thank you! Now I have a name for it!!!
Apr 29, 2013 at 8:06 AM
FREEMBA
  • 1,152 POSTS
Let me know how things turn out for you and if you need more assistance.
Apr 29, 2013 at 7:50 PM
DEESCHMEE
Well, is this a difficult job? Is there anything I need to keep in mind like when I take the valve cover off?
Im thinking the distributor needs to come off first since its hanging by the bottom two brackets
http://www.flickr.com/photos/95359795@N04/8694381524/
Apr 30, 2013 at 6:51 AM
