Distributor
2003 VOLKSWAGEN JETTA
142,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
DDORSEY
I recently purchased this car and I am going to do a tune up on it. Does the distributor necessarily need to be changed if the vehicle is running okay?
Oct 17, 2017 at 7:58 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
No, just spark plugs, a cap and rotor, maybe spark plugs wires, air filter, fuel filter, PCV valve and if the ignition timing is adjustable, check to make sure it is set to spec on your under-hood label.
Oct 17, 2017 at 10:09 AM
Here is a guide that can help you get the job done:
https://www.2carpros.com/articles/how-to-tune-up-a-car-engine
Oct 18, 2017 at 11:59 AM
